302 Block Machining Specs
RE: 302 Block Machining Specs
only the BOSS and Dart blocks which are aftermarket blocks can be bored to that figure....stock I have seen bored to .060 but personally I wouldn't reccommend going past .040 or .030
ya....060. is definatly the most u want to go on a stock 302...and thats a lot..ur gonna have a lot let holding capacity with that much bore...and .125 is outta the picture on a stock block
Technically you could...
But technically, you are likely to run into big problems if you do
The stroke could work. What kind of rod/piston combination are you going to run with that custom stroke?
Maybe I can sonic check the block and see what kinda numbers the block walls are running. Thatwould be the best indication.
It was looking at pieces from a rotating assembly I saw. I forget the height of the pistons but they were obviously 4.125" and the rods were 5.2" long. It also included a crank with a 3.470" stroke with 2.248" mains.
bradleyb
11-27-2015 07:50 PM
