New DR Questions
Old Jan 22, 2008 | 10:15 PM
68CSTANG's Avatar
68CSTANG
Default New DR Questions
OK, I have two main qusetions
1) My LX is mostly stock, T5, with 4.10s, suspension work, and other bolt ons. With a 26" tall tire, will it be geared too low? Would a 28" be too tall?
2) Im looking at either the BFG Gforce DRs (only sizes: 26" or 28"), MT ETs (the tube type) or Hoosier Quick Time DOTs (also a tube type). I would rather not run a tube tho, has anyone done this? I know the tires wont hold air as long but will I run into any other problems? I wanted the ET Street Radials but theyre on backorder until April.
I know this isnt the most exciting thread but can someone plz help me out? The tires are going on a 15x8 Draglite also. Thanks
Old Jan 22, 2008 | 10:40 PM
dimebag's Avatar
dimebag
Default RE: New DR Questions
no go w .the 26s
Old Jan 22, 2008 | 10:58 PM
Mustangkiler's Avatar
Mustangkiler
mickey thompson is the only option.
Old Jan 22, 2008 | 11:56 PM
bighungrymatt's Avatar
bighungrymatt
I agree go with 26's
Old Jan 23, 2008 | 03:44 PM
68CSTANG's Avatar
68CSTANG
So you guys dont think it will be geared too low with 26s? Also has anyone ran the tube types without a tube on the street? Thanks
Old Jan 23, 2008 | 06:52 PM
5.0stanger's Avatar
5.0stanger
I was running 27" tires with 3.73 and it was a little too much tire, but I still went fast. I think if you are worried get a 27"...with 4.10's those would work good. 255/60/15 MT's
Old Jan 23, 2008 | 10:06 PM
68CSTANG's Avatar
68CSTANG
Thanks Stanger, I was going to get the exact tires you used to have (255/60...if Im not mistaking) but theyre on backorder until who knows when. I wanted to use the MT ET Street radial but I think I might try the tube type and then give the radials a shot when they are back in stock.
Old Jan 24, 2008 | 01:58 AM
92GreyGT's Avatar
92GreyGT
I have used M/T ET Streets with out tubes and they held air but every pair of Hoosiers I have had or seen have leaked air with no tubes. 26x10.5 ET Streets with a 4.10 gear is a nice set up.
Old Jan 24, 2008 | 07:25 AM
lxman1's Avatar
lxman1
On a stock engine that only pulls to about 5000rpm, you would be better with the taller tires. 3.35 x 4.10 = 13.74 first gear ratio. It will barely get you to the 60ft mark.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
