SD car
Old Jan 26, 2008 | 02:11 PM
stangbanger87's Avatar
stangbanger87
Default RE: SD car
lxman had the aod nitrousd85 has a 5 spd , he is working on his set up now i went and checked out him and his brothers stuff they ain't no strangers to 5.0's that is for sure just sd is a little trick to work with and converting to mass air is a scape goat for guys who don't want to go down a path less traveled .
Old Jan 26, 2008 | 02:39 PM
nitrousd85's Avatar
nitrousd85
Default RE: SD car
praise the 5.0 god he loves us all even mass air guys
Old Jan 26, 2008 | 03:31 PM
yellow93lx's Avatar
yellow93lx
Default RE: SD car
ORIGINAL: lxman1
Very informative. You a lucky one two. A guy I used to work with has a 88 conv AOD. He had ported E7 heads and a B303 cam. It ran like crap. Lean pops if you hit it from an idle. It did idle ok, but was gutless. I ran better exhaust, ram air, 3.55's on my SD and it ran great. I too would suggest the wet NOS kit. I started with a dry kit and it cost me a head gasket (fixed under warranty), then went to a 100hp wet kit and had no more problems with the timing @ 10 BTDC. I got a killer deal on a 89 MAF set-up when a buddy totaled his 89 so I bought the whole set-up for $100. Now I can add many more mods as the wallet permits.
Mine ran 7.96 @ 86.9mph in the 1/8 mile on worn out slicks and a 1.72 60ft.time. I could have gone faster, but I didn't launch it too hard because it was all I had to drive at the time and couldn't afford to break it[sm=nxsmile.gif] I have since sold the NOS kit and hope to build a 347 soon.
Warranty fixed a head gasket, how long you been running NOS? I remember back in those days it was considered cheating.
Old Jan 26, 2008 | 03:34 PM
stangbanger87
Default RE: SD car
yep he loves all of us i am not against mass air just prevy to sd cause i got one , unfortunately my dads was converted to mass air [sm=boohoo.gif]
Old Jan 26, 2008 | 03:47 PM
dimebag's Avatar
dimebag
Default RE: SD car
ORIGINAL: stangbanger87
dimebag once again you have come through , you should start an sd section !i have taken the advice you have given to me and it is going well i am still searching for the right priced heads now (looking at used cuz my wallett getting thin due to tax season and being self employed ) but i have found most of the parts pretty reasonable .85nitousd should have no problem getting some more go with that combo.
haha, that'd be tight...
and... gt40s, or your ported e7s... either will be "low key"... you cant tell at all that i have heads on my car... any iron head for that matter would be low key
Old Jan 26, 2008 | 04:28 PM
stangbanger87
Default RE: SD car
i am looking at a set of gt 40p's now i found a company that sells rebuilt ones with a 3 angle valve job and are cnc'd for 400 with no core. i thought that was a good deal so i think i am gonna go that route .i emailed you about some 351 heads but it wasn't what they said they were. i am serious you should start an sd section cause this info for these cars , tons of mass air stuff but not realy any sd info . this would help quite a few guys who really don't see the need to spend 500 or so on a conversion.by the way hows the car coming along ,.
Old Jan 26, 2008 | 04:36 PM
dimebag's Avatar
dimebag
Default RE: SD car
i think i know what company your talking about... i looked at them a little
id still go junkyard w. it... its cheaper... just me tho
and yea a SD section would be tight... maybe someone should talk to some one(mod/admin) about it...
and the cars done... just gotta do the gears still.. its runnin great
Old Jan 26, 2008 | 04:58 PM
stangbanger87
Default RE: SD car
glad to hear the car is running good , far as finding those heads in a junk yard aroundhere man they want an arm and a leg for them , just about the same price as the ones i found online .what gear are you gonna run ? i still have to put the 3.73 in mine yet , i decided to go with those so i can still have decent freeway ability . good luck with the gear swap and can,t wait to see your numbers in march .
Old Jan 26, 2008 | 05:04 PM
dimebag's Avatar
dimebag
Default RE: SD car
3.73s... they were free(came in my parts car) so i m just swaping entire rears.... if not these ida went with 4.10s
djbigskrilla
Sep 20, 2022 01:04 AM
chain
Aug 17, 2015 08:52 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
ccwebb
Aug 11, 2015 06:47 PM
