Idle Issue
Old 01-27-2008, 10:01 PM
dothedew1654
dothedew1654's Avatar
Default Idle Issue
I've been having idle issues for a while now. I replaced my IAC and it has improved a little. But if I leave the IAC plugged in the rpms will hang for awhile and then drop down. And when I go to shift instead of the rpms dropping they will rise. But if its unplugged the rpms will drop like their supposed to. At lights tho, the idle will wonder all over the place and in the morning it will idle really low. Any ideas on what to try next? I heard i could possibly clean my MAF. How do i do this?
Thanks
dothedew1654 is offline
Old 01-27-2008, 10:06 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Idle Issue
go to your local parts store and ask for MAF cleaner and remove maf and spary it down inside paying attention to the small wires that read air speed also check for vaccum leaks
mjr46 is offline
Old 01-27-2008, 10:10 PM
dothedew1654
After I clean the maf, should i plug the IAC back in? and let it idle?
Old 01-28-2008, 04:00 AM
lxman1
lxman1's Avatar
YEP. Also your TPS sensor could be bad.
lxman1 is offline
2007StangV6
01-28-2016 06:09 PM
stangin1996gt
09-21-2015 11:01 AM
LivingInThePast
09-16-2015 12:20 PM
Scottyboy187
SVT Forums
09-13-2015 10:23 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Idle Issue
