OMG WTF!!!!!!still wont start
RE: OMG WTF!!!!!!!!!!WONT START
holy sh#t thats stupid not that just the fact i thought something was wrong as if u did nt know i hid most of the wires and i thought that this was leading to a wiring problem.
maybe the motor was just a tooth off as i first thought and i flooded it
lxman refresh my memory when dropping the dizzy in on tdc the rotor points at about 12:30 or so right?
Sounds about right. Does your cap have #1 cast in it?
If so, point the module at about 5 o clock, see where the #1 terminal is on the cap. The rotor should be pointing near there when it is all of the way in.
the distributor is the ECM's source for camshaft position sensing. the fuel pump circuits would be triggered by the engine beginning to crank over, or by you manually spinning the main shaft of ther disty
this might be a stupid question... but nobody else asked... did you set the engine at top dead center on #1 when you installed the distrubutor? when you are trying to start the car does it crank normal, but just wont start?
