Push Button Start
Old Jan 29, 2008 | 10:39 AM
ISwearItsStock's Avatar
ISwearItsStock
Default Push Button Start
Yes i Did search. Every post is either old or for the 05 and up. I have been having a problem with my ignition being able to be turned WITHOUT a key depending on how I put the key in and pull it out. i would like to make it so you need to additionally use a start button that i could hide, so the only way to start is with the button. So you cannot turn the key all the way and start. Just turn to on then press the button.
Can anyone offer some advice??
Old Jan 29, 2008 | 11:55 AM
ISwearItsStock
Default RE: Push Button Start
Anyone??
Old Jan 29, 2008 | 12:05 PM
primetime5.0's Avatar
primetime5.0
why dont you just replace the ignition cylinder?
Old Jan 29, 2008 | 12:15 PM
ISwearItsStock
Because I've always wanted a push button start...
Also to mess with my fiancee. She loves the car. I wont tell her i hooked it up and tell her if she can start the car she can gave it.
Then sit back and laugh....
Old Jan 29, 2008 | 01:58 PM
ISwearItsStock
Someone? Anyone?
Old Jan 29, 2008 | 05:14 PM
stang8689's Avatar
stang8689
Its not hard, you can buy one from the auto store and it has to clamps that go on each side of starter solinoed.
Old Jan 29, 2008 | 05:25 PM
WhiteWindsor's Avatar
WhiteWindsor
Personally i like having a key start my car. I do have push button under hood just because it makes it easier if i'm working on it, adjusting valve lash, checking for spark and anything else i need it for. I use it quite often.
Old Jan 29, 2008 | 09:06 PM
wildsurfer92's Avatar
wildsurfer92
hey where did you get your pushbutton under the hood fastblack? and you have a pic of it by chance?
Old Jan 29, 2008 | 09:08 PM
pastfast125's Avatar
pastfast125
I have some cheapo push button starter from pepboys that I have yet to setup, directions are missing a ton of words so I gotta figure out what gets hooked up to what to figure out how the switch works. Plan is to put the key in the center console in the cig lighter hole, push button wherever I feel like puttin it.
Old Jan 29, 2008 | 09:13 PM
CBurn's Avatar
CBurn
ORIGINAL: FASTBLACK
cool
