Question
Old Jan 30, 2008 | 08:13 AM
BlackFox's Avatar
BlackFox
Default Question
I have all the bolt ons for my car with the exception of the 347 stroker kit. I keep going back and forth between saving up enought to either buy the block and kit from Fordstrokers or just getting the kit and having a machine shop do my stock block. Only main thing im missing is heads. And I cant decide on AFR 185's or TFR High Flows. I dont plan on going over 500hp on this car so my question is. Should I just save my money for other stuff and have the stock block done or save up for a new block? Oh and I have yet to buy injectors, pump, and electrical stuff like msd or what ever. What you guys think??
Old Jan 30, 2008 | 08:20 AM
stang8689's Avatar
stang8689
Default RE: Question
I would buy the 347 short block and AFR 185's
Old Jan 30, 2008 | 08:24 AM
BlackFox's Avatar
BlackFox
so your saying buy the whole thing and not just the kit for my stock block. Why is that?
Old Jan 30, 2008 | 03:33 PM
89gt347's Avatar
89gt347
you'll have to price how much a machine shop will charge to build an engine, then go from there. Different places charge different amounts to do engine work so shop around.
PS~~~~> AFR 185's
Old Jan 30, 2008 | 07:25 PM
stangbanger87's Avatar
stangbanger87
the stock blocks are prone to splitting under high hp , the fordstroker blocks are a thicker heavier cast than the stock one.you can put in valley girdels but idk on how well that works .
Old Jan 30, 2008 | 07:50 PM
Rajun_Cajun's Avatar
Rajun_Cajun
It seems to me that buying the shortblock would be cheaper. I would think that a machine shop would charge more to rebuild your stock block. Plus, you will have to have your stock block notched for the stroker, bored out, possibly decked to ensure a flat mouting surface. The ford stroker short block already has this done and comes assembled. Also, your car wouldnt be down as long, b/c you can transfer all of your parts to your new shortblock, instead of waiting weeks to have your stock block machined and then reassembled. If you have any mechanical knowledge, you could do the labor yourself. Just make sure you GET ALL OF YOUR TORQUE SEQUENCES RIGHT. tTust me, you dont want to spit a headgasket after youve done all that hard work.
Old Jan 30, 2008 | 08:29 PM
5spd GT's Avatar
5spd GT
AFR 185cc or AFR 205cc.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
