Does anyone have this problem or can explain whats going on?
Whenever I start the stang with a cold engine, It instantly idles to 1k and stays there but say I turn it off then right back on it surges from like 600 to 1k for several seconds and catchs a idle.
And I have a seperate question, I am looking into a autometer temp guage what comes with them do I have to tap a hole in the firewall to get the temp sensor on the lower intake? or do i tap into an exsisting wire?
RE: Does anyone have this problem or can explain whats going on?
Check you TPS idle voltage. They will surge if it too high. Shoot for around .95V.
If the temp gauge is mechanical with the metal line, then it must go thru the firewall. I ran mine thru the accelerator cable grommet and sealed it with RTV sealer.
If it is electric, you must run a separate wire and use the provided sending unit calibrated for that gauge. The stock one will not read correctly.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
Seanam
10-04-2015 10:15 AM
stangin1996gt
09-21-2015 11:01 AM
