Engine bay update
Old Jan 31, 2008 | 05:34 PM
02GTman's Avatar
02GTman
Default Engine bay update
I got the engine bay finished the other day. Check it out. Now I have to get some wire loom and start re-routing wires and eliminate the smog hose crap. I no smog laws!
Old Jan 31, 2008 | 05:36 PM
02GTman's Avatar
02GTman
Default RE: Engine bay update
Sorry forgot the pics.
[IMG]local://upfiles/51010/26F8C4FA6F034DB6AD6FBBF9C4063176.jpg[/IMG]
[IMG]local://upfiles/51010/3E9D5A5E0F594011807319984AF1D7F2.jpg[/IMG]
[IMG]local://upfiles/51010/114940CBE0D747B38FD775568394311F.jpg[/IMG]
Old Jan 31, 2008 | 05:59 PM
Shelty's Avatar
Shelty
weld up the holes...
Old Jan 31, 2008 | 06:07 PM
02GTman's Avatar
02GTman
You won't notice them as much with all the sutff back in the bay. Also, that would be alot of extra weight with all those holes.
Old Jan 31, 2008 | 07:38 PM
DoctorD415's Avatar
DoctorD415
Hey, im actually doing my engine bay right now also. Did you keep your brake master cylinder stuff in there when you painted it? What did you remove when you pained it and what did you keep in and just move to the side or go around?
Old Jan 31, 2008 | 07:48 PM
ALMOST STOCK's Avatar
ALMOST STOCK
ORIGINAL: 02GTman
I'll bet no more than a half gallon of gas would weigh, and probably less than that![:@]
Old Jan 31, 2008 | 08:18 PM
bighungrymatt's Avatar
bighungrymatt
yea if u are going to do it, do it right
Old Jan 31, 2008 | 09:17 PM
djh1121's Avatar
djh1121
X2, when that day comes and I do this I want to do it right. I love a clean bay.
Old Jan 31, 2008 | 11:42 PM
02GTman's Avatar
02GTman
I took off all the smog stuff, winshield wiper motor and all the A/C parts.If it could be removed I took it out with exception of the master cylinder. I left the master cylinder and I just painted around it. Ijust moved the wiring harness out of the way.
Doctor D415, post some pics of your progress. Good luck.
Old Feb 1, 2008 | 02:06 AM
Rajun_Cajun's Avatar
Rajun_Cajun
You def should have welded up the holes. You will be able to notice the holes alot more than you think. They will stick out like a sore thumb. And I seriously doubt you would have gained any noticeable weight. Looks good though.
