can someone help me ?
Old Feb 9, 2008 | 12:52 AM
1GT2NV's Avatar
1GT2NV
Default can someone help me ?
i think my car has an electrical problem....every morning i go to start my car and its completley dead ....every morning it gets annoying i installed a new alternator wires and i charged the battery im so curious as to why its doing this any help is much appreciated
Old Feb 9, 2008 | 06:50 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: can someone help me ?
Sounds like there is a draw on there battery. THIS will give you an idea what to do.
Old Feb 9, 2008 | 04:58 PM
WhiteWindsor's Avatar
WhiteWindsor
That's what it sounds like. It must be one hell of a draw to drain the battery overnite. Mine would go dead if i went two days without driving the car, which is all the time. I finally found my problem. My glove box light switch was stuck. I just disconnected it and no more problems.
Old Feb 12, 2008 | 06:11 PM
1GT2NV's Avatar
1GT2NV
can it just be from extreme cold ? because at night my garage is like 25 degrees and i checked the only thing i can think of is my mirror has little lights on it but the bulbs are dead and my girlfriend puts the switches on cause she knows it pisses me off so maybe even though the bulbs are burnt they might still be drawing power
Old Feb 12, 2008 | 06:14 PM
notchbackmatt87's Avatar
notchbackmatt87
draw in the system start pulling fuses.
Old Feb 12, 2008 | 06:19 PM
Maxwelhse's Avatar
Maxwelhse
My S-10 was pulling this same trick, and it got worse when it got really cold... Turned out to be a leaking positive terminal on the battery and consequently corroded battery cable.
Old Feb 12, 2008 | 06:33 PM
95greengt's Avatar
95greengt
have you had you battery checked mine went dead over night and thats what it was if not id say a drain somewhere....
Old Feb 12, 2008 | 06:36 PM
tooslow5.0's Avatar
tooslow5.0
until you get it fixed, just undo the positive cable every night.
Old Feb 22, 2008 | 10:55 PM
1GT2NV's Avatar
1GT2NV
ORIGINAL: tooslow5.0
awesome idea lol i didnt think of that
Old Feb 22, 2008 | 10:57 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
you need to hook a ammeter in series and check to see what the drain is and it's most likely not because the cold if you recharge the battery fully after each discharge
