Speed shifting ?
Old Feb 13, 2008 | 04:48 PM
WhiteWindsor's Avatar
WhiteWindsor
Default RE: Speed shifting ?
Nice explanation bike. The only stock tranny where it is fine to shift using rpm points is in a tractor trailer, I drove them for years and never used clutch unless starting off. On the tractors if your not at the right rpm it wont let you shift into gear even with using clutch. I would not be power shifting, it's just not worth it, too many expensive things to screw up. Have i done it, yea but not often, but i also have a TKO 600.
Old Feb 13, 2008 | 06:34 PM
89Ford's Avatar
89Ford
ORIGINAL: steve355
Can anyone tell me what speed shifting is?I have a srtock T5 and some people tell me you can shift it with out the clutch? I do not want to try this because it makes no sense. Why would all stick shift cars have a clutch if it is not needed ? I am going to the track this summer and I want to make some good passes.
what you are talking about here is how truck drivers drive. you can shift without using the clutch but it wont be a fast motion and its rather slow. It's not recommended in high RPMs, but what you do is put pressure on the shifter towards the gear your are going to shift into and then slowly release on the gas, it will pop out of gear, then you put light pressure on the shifter into the gear you want it to go into, not to much or it will grind but when the RPM or syncro line up or whatever it is that cause it to happen, the shifter will slide right into gear. This method of shifting is common practice for truck drivers b/c it becomes tiresome to constantly push the clutch pedal. It probably extended the life of the clutch but probably not so much the syncros or something in the trans. I do it once in while when feeling lazy. Im pretty good at it and can even down shift now.
Power shifting it really just shifting with out ever taking your foot of the gas pedal, no real skill involved since it is just regular shifting minus one step. but this type of shifting really eats the clutch and if you dont find the gear you will redline the engine
Old Feb 13, 2008 | 06:50 PM
stangbanger87's Avatar
stangbanger87
i ahev done rev shifting on a bike but not in a car , speed shifting i do it alot . but to shift a car into gear with out a clutch sounds like a recipe for disater to me .
Old Feb 13, 2008 | 07:20 PM
capri debris's Avatar
capri debris
bikeboy587 is right on themoney.
Read what he posted because he is correct.
I can do both with my car. I can shift without using the clutch (you better know what you're doing and how a tranny works before even attempting this) and shift without lifting the gas pedal. (the only way Ishift at the track)
Old Feb 14, 2008 | 01:29 AM
90LX2.3's Avatar
90LX2.3
ORIGINAL: stangbanger87
when im riding a bike i rarely ever use a clutch to shift (with the exception of starting off). Just wind it up and slam it into the next gear, they have strong trannies
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
BeatnikFink
Oct 1, 2015 08:00 PM
