Speed shifting ?
Can anyone tell me what speed shifting is?I have a srtock T5 and some people tell me you can shift it with out the clutch? I do not want to try this because it makes no sense. Why would all stick shift cars have a clutch if it is not needed ? I am going to the track this summer and I want to make some good passes.
it's called power shifting its the art of not lifting on the gas when you stomp the clutch pedal while yanking gears if you do it right to the untrained ear it would sound like a automatic
be careful doing this if you are a beginner watch it t5's arent cheap
power shift with caution my friend
ORIGINAL: nitrousd85
i have never done it in my car, but my dad has in mine. scared the sh*t out of me, but hey, he breaks it, he buys it
2 different things
power shifting is mashing the gas, when you get to the top of the gear, you slam the clutched down and shift as FAST as you can and release the clutch again. if done fast enough the engine shouldnt dive far into redline
speed/rpm shifting is not as agressive. you drive in 1st gear like normal (using the clutch from zeroMPH). then as you aproach 2.5-3k rpm, you let go of the gas and pull into second slightly, as the rpms drop the shifter should fall into gear, repeat for the next gear ect
as far as not using the clutch at the top of the gear you could do that if you were running a pro motion 5 speed call them clutch less transmission
only use the clutch to start and stop the rest is shear gear bangin fun
look into a guy brian meyer he runs the nmra hot street i believe or bruce hemminger they both run a pro motion trans.
my opinion on the whole matter...if ur not for sure what ur doing...dont do it..plain an simple lol...otherwise u start breakin sh*t ...then we see the threads (Tryed to shift without clutch, trannys messed up) lol...so just use ur clutch, dont break anything, and have fun...
ORIGINAL: Albizo66
there was a thread on this not too long ago, i remember. power shifting, to my knowledge, is no use of the clutch at all. foot on the gas to the floor at all times, never releasing for shifting, never depressing the clutch, you just get that right RPM
