Lower Intake Leaking at Bolt
Old Feb 14, 2008 | 05:57 AM
cbodie's Avatar
cbodie
Default Lower Intake Leaking at Bolt
Hello again. I have an '88 GT 5.0.
In an attempt to adjust the idle, we found a leak in the upper intake around one of the center mounting bolts. (It acts like a vaccum leak.) After placing a washer on the bolt and sealing it up, we still seem to have the leak. This is a stock intake, and just so you'll know it is a speed density set-up.
Next step is to remove the intake and get it checked for cracks. We're pretty sure the problem is at the bolt. Of course, once all that's done, we'll probably just pick a new intake if it indeed is the problem.
If there's another way to fix this without removing everything, I'd like to know.
Does this sound like a cracked intake? Is this a common problem?
Old Feb 14, 2008 | 10:50 PM
stang8689's Avatar
stang8689
Default RE: Lower Intake Leaking at Bolt
spray carb cleaner on it while running to see where it bubbles
Old Feb 14, 2008 | 10:56 PM
91hatchgt's Avatar
91hatchgt
ORIGINAL: cbodie
The two middle bolts (nearest the middle of the intake) are the bolts that go directly into the egr exhaust port in the lower intake. Sometimes, if the intake bolts havent been checked in a while, the exhaust pressure will slowly back the bolt out causing a small exhaust leak. Usually, you can just take the upper intake off, and properly retorque the lower intake bolts and problem solved. You might check to make sure that the lower intake gasket itself didn't blow out in the same general area. good luck.
Old Feb 14, 2008 | 11:16 PM
AdderMk2's Avatar
AdderMk2
Banned
remove the suspected bolt, squeeze some red RTV silicone into the hole, screw the bolt back in
Old Feb 14, 2008 | 11:40 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
if nothing else works.. just rplace the gaskets
JonnyBlazeGT
Nov 3, 2015 01:10 AM
Cavedawg
Sep 17, 2015 09:51 AM
GimpyHSHS
Aug 29, 2015 06:30 PM
Itzjoe
Aug 26, 2015 08:15 PM
91StangOwner
Aug 20, 2015 11:34 PM
