For everyone telling me I need a cam....
Ok, I got a cam, its being installed as we speak. its a trickflow stage one w/ my crane 1.7 rr, so it should be good for around .530-540 lift. I also am having force fed performance install some bosch 28# ls1 injectors and hardened pushrods. it should all work well with the dyno tune. i guess well see, i wont be seeing my car until around wed. feb 20. maybe now should make some decent numbers?![8D]
has anyone had problems with the stock 2 peice push rods? the ball breaking off the end? keith at forcefed said theyre crap and break easily.
also, does ford make honey comb type springs? i think when i got the gt40 heads, they were already upgraded with beefier springs, because they look WAY beefier than the stock e7 springs.
its always recomended to run the hardened pushrods with a cam upgrade, make sure you check your PTV clearance .530 might be too much but im not sure as ive never swapped a cam on 5.0 with stock internals
ORIGINAL: P.S.I.cho
lift has nothing to do with ptv.......it's a result of the timing events that are occuring..and hardened push rods are reccommended on heads where such things as guide plates are used
folivier
Tennessee Regional Chapter
Oct 2, 2015 05:32 AM
mrappe
Sep 26, 2015 10:16 AM
