cam selection 303
Old Feb 18, 2008 | 08:47 PM
benidorm50's Avatar
benidorm50
Default cam selection 303
303... afr 185 heads..bbk ssi intake (I know not very popular)..70 mm...1.6 hs roller rockers..full length headers..c4..3.50 gear..looking for cam suggestions..thanx
Old Feb 18, 2008 | 08:54 PM
benidorm50's Avatar
benidorm50
Default RE: cam selection 303
meant 306..thinking of a 303 cam
Old Feb 18, 2008 | 09:12 PM
Rajun_Cajun's Avatar
Rajun_Cajun
F-303
Anything bigger and you'll need to notch those pistons.
dimebag's Avatar
dimebag
3.55 gear?
anyway... comp xe line, or custom
Old Feb 18, 2008 | 09:16 PM
dimebag's Avatar
dimebag
**** an f cam... if anything similar id go xe270... not F
Old Feb 18, 2008 | 11:01 PM
ih8chevy's Avatar
ih8chevy
dont u need to notch the pistons with these heads anyway.
ORIGINAL: Rajun_Cajun
F-303
Old Feb 18, 2008 | 11:07 PM
H0SS302's Avatar
H0SS302
Not to hijack, just to clear up some things for myself: are the ford letter cams just kind of generic grinds for easy and quick cam choosing?
i dont know much about cams(the numbers confuse me and i dont know what they mean)
i want an e cam because i love the lope but a lot of ppl keep telling me no lol
Old Feb 18, 2008 | 11:23 PM
Mustangkiler's Avatar
Mustangkiler
Pretty much, and just older technology, steeda trickflow comp crane lunatithere all better cams mainly due to there dual pattern.
Old Feb 19, 2008 | 10:40 AM
5spd GT's Avatar
5spd GT
Ford Racing Camshafts
B303
- 224*/224* 284*/284* - .480"/.480" - .300"/.300" - 112* - 107* ATDC /117* BTDC - 3,300-5,100 RPM
Overlap: 60 degrees.
1.6 Rocker Ratio
Intake Opening: 5* BTDC
Intake Closing: 39* ABDC
Exhaust Opening: 49* BBDC
Exhaust Closing: 5* BTDC
E303 - 220*/220* - 282*/282* - .498"/.498" - .311"/.311" - 110* - 110*/110* - 2,500-5,500 RPM
Overlap: 62 degrees.
1.6 Rocker Ratio
Intake Opening: 0* BTDC
Intake Closing: 40* ABDC
Exhaust Opening: 40* BBDC
Exhaust Closing: 0* BTDC
F303 - 226*/226* - 288*/288* - .512"/.512" - .320"/.320" - 114* - 109*/119* - 2,800-6,000 RPM
1.6 Rocker Ratio
Intake Opening: 4* BTDC
Intake Closing: 42* ABDC
Exhaust Opening: 52* BBDC
Exhaust Closing: 6* BTDC
X303 - 224*/224* - 286*/286* - .542"/.542" - .339"/.339" - 112* - 107*/117* - 3,500-6,500 RPM
1.6 Rocker Ratio
Z303 - 228*/228* - 290*/290* - .552"/.552" - .345"/.345" - 112* - 107*/117* - Up to 6,500
Overlap: 66 degrees.
1.6 Rocker Ratio
Intake Opening: 7* BTDC
Intake Closing: 41* ABDC
Exhaust Opening: 51* BBDC
Exhaust Closing: 3* BTDC
Custom grind is always the best method, but not always the most affordable.
Look to spend an extra $130 or so for a custom grind cam.
It is well worth it to me for better driveability and power at the same time for those nice heads you have.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
carid
Jul 8, 2016 09:55 AM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
