valve spring Q
Old Feb 25, 2008 | 07:56 PM
stangbanger87's Avatar
stangbanger87
Default valve spring Q
ok i am running a gt40p set up and i have prchased a xe264hr comp part #35-349-8 and i was wondering if anyone else is useing this cam and can give me the rcomendation for what valve spring to use with the cam . i know you can get the complete kit but i already baught the cam and now need to know the right spring for it as comps site will not let you pull up the recomendations , thanks for the help guys . or does any one know the springs recomended for the f303 they should work with this cam too .
Old Feb 25, 2008 | 10:25 PM
dimebag's Avatar
dimebag
Default RE: valve spring Q
its like the 986 springs from comp or some ****
go to summit, find your cam, and then look at suggested parts, those springs should come up
Old Feb 25, 2008 | 10:58 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
if it's the 986 springs I have a set that is lightly used..I went heavier as I needed to..but I'm willing to part with them if interested..PM IF SO....... the 986 are a dual spring set up and will require the seats be machined.....f-cam use A50 SPRINGS AND B50 retainers I believe or the other way around..can't remember??
Old Feb 26, 2008 | 06:03 AM
stangbanger87
thanks guys and mjr46 i will be pming you
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
CS2007
Jun 25, 2019 09:45 PM
mungodrums
Sep 28, 2015 10:54 PM
