OBD Scanner
Old Mar 2, 2008 | 08:08 PM
CantStopTheFox...'s Avatar
CantStopTheFox...
Default OBD Scanner
OK....my buddy has an OBD I and II Scanner.......and I plugged it in to both my 04 Explorer (to check my tranny problems, it came up with no codes).......and then the OBD I to the Mustang....
When I started it up, it read, "Reading Codes" and it ran my motor up high, then low.....started blowing black smoke out the pipes......and then it reset to the main menu, and brought the car back to normal.
During the test the check engine light was going on and off, the idle was going up and down....but in the end, it reset without telling me nothing [:@]
Is this normal? Should I try something different?? I have no expereince with pulling codes..........
Old Mar 2, 2008 | 08:32 PM
PJC Racing's Avatar
PJC Racing
Default RE: ODB Scanner
It is normal for the car to act like that when it is tested running. If there were any codes the scanner should have indicated them. What scanner is it?
Old Mar 2, 2008 | 08:34 PM
CantStopTheFox...
Not sure the type.....but after the test, it did nothing but reset and go back to the main menu.
I am wondering if the scanner just crashed, or if there was nothing to report
Old Mar 2, 2008 | 08:39 PM
PJC Racing's Avatar
PJC Racing
If it was an older Snap-On scanner, (I'm going off memory here) you have to go to the retreive fault codes from the menu. If that screen is empty there is no codes. If it one of those part store bought ones who the hell knows, they usualy don't tell you crap.
Old Mar 2, 2008 | 08:47 PM
CantStopTheFox...
ORIGINAL: PJC Racing
Not sure where he got it, but it did look like a good one......but what the hell do I know
I think that it just went empty.....I think my car shorted it out or something.....reminds me of a Windows computer I tell you, after it was all done, my alarm started doing some wierd things. I had to disconnect my battery for a half an hour to let it reset....
BOB ROME
Jul 26, 2023 01:54 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Big Al's 03
Sep 16, 2015 07:31 PM
TfcCDR
Sep 14, 2015 12:08 PM
