19# injectors enough?
Old Mar 3, 2008 | 12:29 AM
kweb288's Avatar
kweb288
Default 19# injectors enough?
hey guys, so i am going to be upgrading my intake with a lightning mass air meter from anderson motorsports, a power pipe, 75mm throttle body, and a holley systemax intake. My car already has 1.6 aluminum rr, and an e303 along with full exauhst. are the 19# injectors enough for right now, or will i be running lean and need to upgrade to 24#ers?
Old Mar 3, 2008 | 12:42 AM
jtmustang's Avatar
jtmustang
Default RE: 19# injectors enough?
why all that stuff before the new heads? or am i missing something i know you have been posting alot lately but what are your plans ?
Old Mar 3, 2008 | 12:51 AM
kweb288's Avatar
kweb288
well im going to put the intake on first working from the mass air back, i already have the loadio mass air from anderson motorsports, i was originally going to go s/c but i started looking at price of doing everything and decided i would just do all motor/a little nitrous. So im going to spread out the cost of everything so that i dont go bankrupt.
I go on spring break on friday (ISU) and anderson ford motor sports is 30 min's away from me so im going to go down before heading home and pick up the rest of the intake. figure then i can save up for heads and a new cam for the beginning of summer then
Old Mar 3, 2008 | 01:23 AM
jtmustang's Avatar
jtmustang
yeah the injectors will be good until the heads/cam and then you said nitrous then i would go 30's
Old Mar 3, 2008 | 01:38 AM
w8less's Avatar
w8less
yea the 19's will be fine for now
Old Mar 3, 2008 | 11:40 AM
kweb288's Avatar
kweb288
mk thanks guys
Old Mar 3, 2008 | 02:07 PM
Chrisinkw's Avatar
Chrisinkw
what items would make you need bigger than 19 lbs???
I have E303 cam, port and polished heads, and a GT40 tubular intake soon to have 75 mm MAF and 70mm TB and headers, exhaust, CAI are 19lbs ok or?? dgo to 24's
Old Mar 3, 2008 | 02:21 PM
kweb288's Avatar
kweb288
with the increased air flow you are getting more air then fuel which makes the engine run lean. You shouldnt have to worry to much, but if you want to maximize the combination it would be recomended to move up in size
Old Mar 3, 2008 | 04:26 PM
Rajun_Cajun's Avatar
Rajun_Cajun
19's will support 300hp. Im at the limit as we speak. I need 24's![:@]
[/align]
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Dathan
Oct 5, 2015 05:52 AM
MacSerio
Sep 27, 2015 01:05 PM
mltdwn12
Sep 23, 2015 08:54 AM
