where to put starter solenoid
RE: where to put starter solenoid
Maybe the 89's were different [sm=smiley24.gif]but that is every wireincluding the hood release cable and the head light harness that ran on the drivers side.
Believe it or not... that solenoid is the original solenoid it's never been changed.
ORIGINAL: Hung Like a Stang
As I've got my stang tore down, i'm hiding the wires and making the engine bay pretty. I"ve done tons of seraches about the wire hiding part, but only one suggestion on where to put the noid, and thats simply on the inner fender on th drivers side.
Has anyone put thers anywhere else? Maybe over on the passenger side somewhere, closer to the stareter?
and I was still kind of uncertain as to what he fastened to on the inner fender well on the drivers side if I just ended up keeping it on that side.
You thought that the solenoid looked like it was on the passenger side?
It's on the drivers side.
Yes the fenderwereremove when I took that pics because it was my second time of hiding wires.
My first attempt looked like this where you could see some of the wires and some of the brake lines run under the pinch weld and it wasn't what i was looking for.
2 years later ( this time I pulled the fenders) I put the wires inside andbehind the dash and redid the brake lines so that there not as noticable and put everything behind the fenders.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
