how much oil does your 5.0 burn?
RE: how much oil does your 5.0 burn?
i use 10w40 and its about a quart little low by the time i need to change it anyways. then again my front drain plug is stripped and it leaks a little out there as i drive.. never any on the ground.. but i can see droppletts around the drain plug
hopefully I burn none... but the underside of my car is wonderfully clean, no oil combined with dirt and road grime crap as far as I can see.... which is opposite of what my old buick used to look like... that was a really greasy old car.
dont know of her past, but I baby her, I cant afford to break her right now
Too much! Car has only 99,000 miles but sat for 8 years before I bought it. I suspect that the oil rings are shot. Still has good compression. Also leaking bad from front main seal. 1 quart = 700 miles.
