PSI
Old Mar 22, 2008 | 11:02 PM
nitrousd85's Avatar
nitrousd85
Default PSI
what is stock psi per cylinder on a 5.0
i ran a compression test pulled 150 psi per syl. is this normal or what should it be for a car at 200k let me know
Thanks
Old Mar 22, 2008 | 11:05 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: PSI
for 200k that's not all that bad
Old Mar 22, 2008 | 11:13 PM
nitrousd85's Avatar
nitrousd85
Default RE: PSI
ok i was going to re ring it but instead i will just give her some new rod and main bearings oil pump pick up
thanks fella
Old Mar 22, 2008 | 11:23 PM
mjr46's Avatar
mjr46
Default RE: PSI
well if you have the motor out and apart..it wouldn't hurt to do so...if there is a ridge on the top of the cylinder wall cut it with a ridge reamer and hone it and install new rings....that's if it's out and apart
Old Mar 22, 2008 | 11:28 PM
r.barn's Avatar
r.barn
Default RE: PSI
Do a leak down test to see "how sealed up your engine is"
Compression test is to see if cylinder builds pressure while moving
Leak down test puts pressure on the cylinder and makes sure everything is sealed ( ie rings and valve seats. )
http://www.toolhawker.com/Cylinder-L...tem_35486.html
Old Mar 23, 2008 | 09:15 AM
nitrousd85's Avatar
nitrousd85
Default RE: PSI
yes i pulled the heart out pulled the heads the ridge was like a grease i simply wiped it away still had good cross hatchings left in it
had like a metallic look to the oil wasnt sure what that was figured it was normal wear
Old Mar 23, 2008 | 09:34 AM
mjr46's Avatar
mjr46
Default RE: PSI
heck since it's apart...hone it and put some new rings in....won't hurt it= cheap insurance too!!
Old Mar 23, 2008 | 09:49 AM
nitrousd85's Avatar
nitrousd85
Default RE: PSI
with like a dingle ball hone i also have a set of arp main studs and wave loc pro rod bolts
to install should i let the rods and pistons set over nite in kerosene or chuck em in the parts washer and scrub em up
my car takes a metric file fit ring correct
Old Mar 23, 2008 | 12:37 PM
backfire2007's Avatar
backfire2007
Default RE: PSI
hell if you have it apart you oughta put some forged pistons inn there incase of any future boost
Old Mar 23, 2008 | 01:17 PM
nitrousd85's Avatar
nitrousd85
Default RE: PSI
already have forged pistons
jwog666
Dec 27, 2021 08:09 PM
TCStangerv6
Oct 11, 2015 05:57 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
LiquidDrink
Sep 29, 2015 10:06 AM
SteelerNation82
Sep 16, 2015 07:11 AM
