Turbo Questions
Turbo Questions
So I'm thinking about going with a turbo kit in the future here, and I have some 3.73 gears here at my house to install. I was told that I would be better off with the stock gears and a turbo, is that really true?
And then a Tweecer, anybody have one? Any experience with one? Would it be good to get one for tuning?
And then exhaust, whats the reason you can't run chambered mufflers with a turbo setup? Would an open downpipe be rediculously loud for street use? If I do keep a full exhaust and can't use the flowmaster mufflers, what other ones should I use?
RE: Turbo Questions
Not unless you are looking to set a top speed record.
3.73s are perfect for an NA setup or a power adder. I have 4.10s and am strongly considering going lower once I addthe blower. Do yourself a solid and buy an aftermarket carrier. The trac lock has some disadvantages when it comes to cornering and handling gobs of torque. Another $300 or sogets you a rear end that will handle pretty much anything a 5.0 can throw at it.
RE: Turbo Questions
turbo works off of load...lower numerical gears put more load on the engine, which means quicker turbo spooling. 3.27's are awsome for turbos, 3.55's are ok too, 3.73 might make the turbo not get to full boost until a much higher rpm.
4.10's and a 5speed generally dont make any boost in 1st b/c of this.
i have a tweecer, just fried mine, should get it back soon. im still new with it but have a buddy that has a s/c car w/ the tweecer and he knows his stuff so i will be pretty good by the time im done.
backpressure+turbo=bad
turbos dont like backpressure, straight through or turbo style mufflers are needed. the turbo quiets down the exhaust note alot, it acts as a muffler in a scence.
RE: Turbo Questions
ORIGINAL: 94StinkinLincoln
Is the tweecer something I'd NEED for the car to be tuned or is it an option?
RE: Turbo Questions
a tuner would be nice, and a/f wideband gauge is a nice tool also!!!
inovative<<---probably ddint spell that right..makes a nice wideband with a good data logger you be a needing a laptop also nothing fancy just a cheapo off ebay will work for dataloggin. I paid 80 bucks for mine.
as far as tuning goes good luck with that tweecer it takes awhile to learn how to tune with it.
treesloth
09-28-2015 07:03 AM
