Looking for some specs..for those that have these..
I would please like to know the following
-What its made out of (then powder coated black)I assume
-How long/how tall the plate is
-dimensions of where each screw is
I'm going to custom make one fitted for 2-1/16 gauges. I just need some specs first...
Thanks!
RE: Looking for some specs..for those that have these..
i dont have one, but from the looks of it, thats a radio or AC/vent setup, shouldnt be hard to use some cardboard to fabricate the plate, and place the mounts, etc
Just tookout the vents here in the shop (computer in the shop). Anyways looks like i'll need to make a back plate also then bolt them into each other. I'm making it out of steel....afterwards can I just spray can it flat or gloss black? or will it not stay on [&:]
Pro's right about the a/c deal. I have that same set up. I'm not going out to measure it right now. If your making your own plate you need to primer before paint or i think it will flake off eventually. If i'm not mistaken you can buy that whole kit together as an assembly.
OK, i see. I did not catch thesize difference you stated earlier. Getting late and i have to be at work at six in the morning. I'm hitting the sack.
