Supercharger
RE: Supercharger
well here is the setup i'm running, $ really isnt a problem i just dont want 5 grand in a supercharger, cuz then i midas well run a turbo charger.
DSS race block
CHP forged stroker kit
Trickflow Twisted Wedge heads w/ valvespring upgrade
Trickflow Stage 3 Camshaft
Trickflow Rockers and Lifters
Trickflow Box-R series manifold
Trickflow Underdrive Pulleys
FRPP 72lb injectors
BBK fuel pressure regulator
BBK 75mm Throttle Body w/ EGR plate
BBK Long Tube headers
BBK H-pipe
SLP loudmouth 2 3" exhaust
Jet Mass air meter
Motorvation Custom Chip
Vemon Performance Module
DSS race block
FRPP 72lb injectors
BBK H-pipe
Jet Mass air meter
RE: Supercharger
DONT do a kenne bell, I used to be so into them and wanted one for so long but the twin screw is NOT needed on a mustang. Your already pushing out more torque then hp in a mustang ESPECIALLY with your set up which generally means more power in the lower rpms, Im loving those 72lb injectors btw, those are nuts. The twin screw gives you more power through the whole band of rpm from like 2200-5500 but doesn't boost like centrifugal blowers do. Search videos online of KBs versus like a paxton or a vortech, you'll thank me. I say do a vortech with a high psi and you'll be very happy and save yourself money compared to a kenne bell.
RE: Supercharger
Why not turbo? You already have teh fuel system, with that budget you can get a complete turbo, and then have some cash left over for a tune/misc. items. If my blower cannot be rebuilt cheaply this is the route im going
quicktimeturbosystems.com
RE: Supercharger
so ya think just get the turbo, and forget the supercharger all togethor? i don't know if anyone has heard of ponydown or not, but for the price i don't think ya can beat them. i'd rather have a turbo but i thought the tuning and everything was more expensive. i know if ya have a turbo running 12 psi compared to a supercharger running 12 psi, the turbo will build a ton of more power. i'm kinda trying to keep $ put back for other cars, i have 4 mustangs, but thanks guys so far for the help keep it coming, cuz i still haven't made my mind up yet.
RE: Supercharger
you spend what it takes to make the combo right and perform right or else[sm=shootshoot.gif]kaboom..you need a adequate fuel system..supporting mods, boost retard/ ignition capable of that , supercharger kit, a tune to make sure timing and fuel are optimal after it's all said and done...gauranteed your budget will be exceeded
