Poly Bushings
Old Mar 31, 2008 | 02:41 PM
REDS 5.0's Avatar
REDS 5.0
Default Poly Bushings
I've been eyeing the Hyperflex Poly Bushing kit(suspension) for my GT('90). Does this really make that much difference? I have the motor mounts and trans. mount in already. I put this kit on my '66 F-100 and it is great as the factory bushings were toast. Simple to install on the truck, but what about the Mustang? What else could I do to make this thing have a good ride quality?
Old Mar 31, 2008 | 04:46 PM
greenstreak9205's Avatar
greenstreak9205
Default RE: Poly Bushings
explain what you mean by "good ride quality"?
Old Mar 31, 2008 | 05:03 PM
REDS 5.0's Avatar
REDS 5.0
ORIGINAL: greenstreak9205
LMAO! Better than this stock set up. I do not care about "riding on rails" but I would like it to be "tight" or "firm". It just seems sloppy and I think my stock stuff is showing its age. Its kinda harsh on the bumps and dips. I may make it worse but I think I just need to stiffen things up to get rid of the sloppy-ness of it. I wish to retain the stock height as well.
Old Mar 31, 2008 | 05:09 PM
greenstreak9205
i kno you're asking about bushings but remember that the fox chassis is like a wet noodle right in the middle. a set of good subframe connectors would go a long way to help bring the ride better. bushings would make some improvement yes, but how bout just buying new components that have better bushings in them already? UCA's LCA's.....stuff like that. once again, i realize thats not qutie what ur askin and is starting to veer from the topic but why not just upgrade the component that you're putting the bushing on also just my opinion
Old Mar 31, 2008 | 05:19 PM
REDS 5.0's Avatar
REDS 5.0
Not straying at all. I've considered this and may do it. I feel some quality parts will be a much better way to go. I've looked at Maxuim Motorsports stuff in catalogs, I just do not want to go to far with my gal. I may start withSubframes and upper and lowersto see the difference a piece at a time. May make for a good test to see what differencethe different components make.
Reading on subframe connectors, welded are the way to go, correct?
Old Mar 31, 2008 | 05:27 PM
greenstreak9205
bolt in<weld in<thru the floor
mtgldr
Feb 3, 2024 09:00 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Explosive
Oct 2, 2015 07:45 AM
UrS4
Sep 30, 2015 10:13 AM
Sep 16, 2015 07:53 PM
