KOER codes
Old Apr 6, 2008 | 02:59 PM
mattwright101's Avatar
mattwright101
Default KOER codes
went to pull my codes earlier
got a 67, 81, 82, and 95 on KOEO
it wont let me run the KOER test though
it gives me the engine id code then just sits there without doing anything else
Old Apr 6, 2008 | 03:09 PM
mattwright101
Default RE: KOER codes
i even tried holding the clutch in as someone has said about code 67
still wouldnt run
Old Apr 6, 2008 | 03:18 PM
Joel5.0's Avatar
Joel5.0
Need to fix code 67 in order to run the KOER, the system will not allow a KOER to run due to "safety" (not in-neutral) reasons. You may want to check the harness connectors for the clutch pedal switch assy., and install a jumper cable to the corresponding one. One of the connectors that plug into the switch assy, should take care of code 67.
Old Apr 6, 2008 | 03:20 PM
mattwright101
where is that thing located?
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
