Replace thermostat
Please chime in if you have done this before
yes i know it has to be one of the easiest things to do but i'm getting conflicting answers
so i bought a new thermostat cause the dynosheet says im getting too hot up top and losing power.
i bought a new houseing cause it was cheap and a felpro gasket. the question is this: do i need to use that little silicone package that they sold me at the auto store? it says i have to let it cure for 24 hrs!! i need this car EVERY day for work and school so if i dont NEED the silicone i will just use the gasket. who has done this with just the gasket AND is leak free?
what i did was use a TINY little bit of silicone to make the t stat stick to the housing. just enough to make it stick though
you dont want any of the silicone to get in the way of the opening on the t stat
than you just line the gasket and housing up and bolt it back in.
tkaes about 30 mins if you try hard enough
ORIGINAL: nseoi
ORIGINAL: 93 LX FiveO
hope u got the waterpump off, otherwise gunna be a bit time consuming.
the lower bolt is a PITA to get off, especially since it backs out against the waterpump.
thanks for all the tips btw
I just put a new one in maybe a month ago and all i did was loosen the distributer and got a wrench on the bottom one with out taking anything else off.......as for silicon the gasket i bought had a peel off side with addhessive so it stayed and place so none was needed and i am leak free!!!
ORIGINAL: Jfsram
Can you explain this more? Is your car overheating?
ORIGINAL: nseoi
i also have an aluminum radiator and electric fan but dont want to install that until i have a better alternator.
My buddy just did his....installed it, started it....it leaked
I told him to put some sealer and let it sit overnight....he did it, started it up in the morning for work.....Perfect!
Good Luck!
Good Luck!
ORIGINAL: nseoi
i wouldnt say comepletly overheating but it is running very hot. i have not upgraded anything in my cooling system after all my mods so this was my first recommendation.
ORIGINAL: Jfsram
ORIGINAL: nseoi
