Helpful advice needed please!!!
Old Apr 13, 2008 | 01:50 PM
flmustang's Avatar
flmustang
Default Helpful advice needed please!!!
Hello everyone i'm new to the forum and was hoping to get a little help on here. I'm going to be rconditioning my 1990 mustang 5.0 and have decided to just keep it street strip friendly with air conditiong still. I have a gt-40 truck upper and lower intake system, 65mm t/b, 80mm mass air, k&N,21# injectors, 3:73 gears, BBK shorty headers and H-pipe w/ flowmasters, GT-40 iron heads and heres the kikker, whatCAM/rocker armdoes everyone recomend for stock compression , good idle, but i want it to sound like a bad mother ----er! I am looking for some good get up and go but still retain about 17-20 mpg. any opionions will help , thanks.
Old Apr 13, 2008 | 02:15 PM
crueheadstang87's Avatar
crueheadstang87
Default RE: Helpful advice needed please!!!
the xe series from comp cams will work well with your set up. the ford letter cams are out dated technology so they really wont make the best out of your combo. but if you do decide to use one the f cam with 1.6 roller rockrs has a nice sound and decent power range. but just about anyone on the forum will tell you to call comp cams, lunati or any other cam manufactorer and talk to one of their techs and tell them what you are running and let them reccomend a cam for you or make a custom grind cam for you. that is really the only way to get the VERY BEST of both worlds. And as always when upgrading a cam alwys install matching valve springs, retainer, locks, and other goodies to ensure a long lasting valverain, and always make sure to check piston to valve clearance on ANY CAM INSTILLATION, as all engine are different. hope this is of some help to youl Pm me if i can help you with anything!
Old Apr 13, 2008 | 04:35 PM
crueheadstang87
bump
Old Apr 17, 2008 | 01:44 AM
flmustang's Avatar
flmustang
how do i check pisto to valve clearence, is it an easy science.
djbigskrilla
Sep 20, 2022 01:04 AM
SANDY21
Aug 17, 2015 02:41 PM
joe73Qcode
Aug 15, 2015 09:49 AM
defarmer
Aug 13, 2015 06:40 AM
