New engine mounts broke during install!!
Old Apr 14, 2008 | 09:59 AM
camaroeater's Avatar
camaroeater
Default New engine mounts broke during install!!
While tighteningthebig nut (13/16)that goes on theBolt that protrudes from the enginemount, thebolt broke looseinside themount. When I turn the big nut thebolt justrotates inside mount, so I can not loosen or tighten the nut. Does anyone know of a way to chisel the nut off.
Old Apr 14, 2008 | 11:00 AM
FivePointOhh's Avatar
FivePointOhh
in limbo
Default RE: New engine mounts broke during install!!
air chisle that b!itch off. either that or clamp the bolt if you can get ahold of it and loosin the nut as much as possible. get pics up if you can it might make it easier to give you better suggestions.
Old Apr 14, 2008 | 11:06 AM
5.0stanger's Avatar
5.0stanger
Cut a groove in the end of the bolt so you can hold it with a straight screw driver and turn the nut off.
Old Apr 14, 2008 | 11:35 AM
r.barn's Avatar
r.barn
you're screwd ......... have fun with that nightmare.[:@]
camaroeater
There is about 1/8 spacing behind one nut and less on the other....so it would be hard toclamp bolt. One nut is theaded on so the bolt endis flush with the top of the nut(not protruding out of nut). The other bolt endis onlythreaded only half way into the nut.
Old Apr 14, 2008 | 02:10 PM
5.0stanger's Avatar
5.0stanger
Got a saws all? Cut that bolt off. What kind of crappy mounts did you buy that are falling apart?
Old Apr 14, 2008 | 02:19 PM
camaroeater
I got the mounts a Checker...there cheap but would not of broke if I didn't force nut on. I went to auto zone and got some mounts and there the same as the checker ones. I would get poly mounts, just don't have 200.00. I thinking of a chisel and a sludge hammer or some kind of saw.
Design1795
Jan 24, 2017 10:38 PM
Design1795
Aug 24, 2015 04:41 PM
classic69FB
Aug 12, 2015 11:58 PM
tmdm
Aug 7, 2015 10:24 PM
