roll cage? install?
looking for a 8 or 10 point cage how much lighter is the chromoly over the mild steel and can anyone give me a vendor that they have used for this before? There are so many prices out there its hard to get the good info, I will be welding it in my self so I am looking for something that is notched and I have no griding to do. Has anyone done this before?
i would like to know to about the goods?/bads with the mild steel and chromemoly
i have looked at wolfe,team z they have some decent setup with or without tubing notched and what ever u want really
Moly needs to be tig welded and in theory the joints should be annealed after, otherwise they are more brittle than the surrounding metel. A typical 6 point roll bar is about 20lbs lighter if it is moly. Mild steel is cheaper and can be mig welded with annealing, it is also A LOT cheaper. Most of the pre-bent cage kits will still need some tweeking. Don't exspect them to "slide right in".
50, 95, cage, estimate, install, installation, maximum, motorsport, motorsports, mustang, roll, rollcage, s197, sn95
