MOD'S FOR MAY HELP!!!!!
Old Apr 24, 2008 | 11:09 PM
cheetha94607's Avatar
cheetha94607
Default MOD'S FOR MAY HELP!!!!!
OK SO I INSTALLED MY 347 ENGINE AND PERFORMANCE MODS AND I'M TRYING TO FIGURE OUT WHAT IM GOING TO DO FOR THE MONTH OF MAY. CURRENTLY I NEED NEW INJECTORS(BECAUSE I'M RUNNING STOCK INJECTORS),FRONT BUMPER DUE TO SPLIT IN MY FRONT BUMPER, LOWER CONTROL ARMS STOCK AT THE TIME, WONT PANHARD BAR DUE TO REAR DIFF MOVEMENT, BIGGER TIRES FOR MORE TRACTION, COWL HOOD MY INTAKE WONT CLEAR MY STOCK HOOD WITH1 INCH SPACER. WELL AT THIS TIME THAT IS IT.I WILL NEED ALL INPUT TO MAKE MY FINIAL DECISION. THANKS
Old Apr 24, 2008 | 11:11 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: MOD'S FOR JUNE HELP!!!!!
hmmmmmmmm..I don't see the mod listed in your poll that you really need!!! GEARS FTW!!!
Old Apr 24, 2008 | 11:15 PM
cheetha94607
OK I WOULD ADD GEARS BUT WOULD IT REALY HELP WITHOUT TRU-TRAC DIFF?
Old Apr 24, 2008 | 11:17 PM
mjr46's Avatar
mjr46
you should have trac-loc already in your 5.0 stock...I'M STILL RUNNING FACTORY trac-loc set up in my 85 with no probs and 3.73 's
Old Apr 24, 2008 | 11:23 PM
cheetha94607
OK BUT I HAVE NEVER REPLACE THE CLUTCH PACK ONLY HAD THE 91 STANG FOR ABOUT 1 1/2 YEARS. SOULD I REPLACE THE CLUTCH PACK IF I CHOOSE TO REPLACE THE GEARS.
Old Apr 24, 2008 | 11:43 PM
mjr46's Avatar
mjr46
ORIGINAL: cheetha94607
not a bad idea!! once the unit is out and on a bench.. replacing the clutch pack is a 15 min job= easy
Old Apr 25, 2008 | 02:31 AM
kweb288's Avatar
kweb288
i would personally say injectors if you are still running the stock 19#'s on a stroked engine so that it doesnt go to lean and you dont destroy it
Old Apr 25, 2008 | 02:49 AM
w8less's Avatar
w8less
ORIGINAL: kweb288
agreed
Old Apr 25, 2008 | 10:59 AM
bighungrymatt's Avatar
bighungrymatt
I say gears and tires
Old Apr 25, 2008 | 11:20 AM
sleeper_inc's Avatar
sleeper_inc
Holy caps lock[&:][&:][&:][&:]
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
TimeLord101
Oct 1, 2015 06:40 AM
firecoyote
Sep 27, 2015 02:37 PM
