trans temp
Old May 2, 2008 | 05:36 AM
ctgreddy's Avatar
ctgreddy
Default trans temp
does anyone know what my trans temp should be around? It floats between 150 while easy driving and gets up to 180 every now and then under my "normal" driving. hopefully this is normal. Also since the stock thermo is 195 degrees that should stay at about 200 right? I'm thinking of getting a 180 for it just for shts and giggles.
Old May 2, 2008 | 09:36 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: trans temp
ORIGINAL: ctgreddy
150 to 180 is not bad..when you get into the 220-240 range then start worrying...which when hot lapping at the track it'll climb to such after numerous hard runs
Old May 2, 2008 | 09:48 PM
94StinkinLincoln's Avatar
94StinkinLincoln
umm, aode's have t-stats in them? didnt know that, i know some cars have them but i didnt know ours did.
my tranny temp never got over 180 either, but i got a cooler infront
Old May 2, 2008 | 11:23 PM
mjr46's Avatar
mjr46
ORIGINAL: 94StinkinLincoln
^^^^^^think about it....that's not what he means..I understand his line of thinking...since the car is equipped with a t-stat of 195 and the aode tranny cooler is housed within the radiator.. the fluid for tranny should get no hotter than coolant temp surrounding cooler so if he can lower coolant temp by using a cooler t-stat.. that in turn would be reflected in cooler trans fluid temp...that is of course unless you have an external cooler in addition
Old May 5, 2008 | 09:23 PM
ctgreddy's Avatar
ctgreddy
actually your both wrong i just forgot to mention that when talking about the tstat i was meaning coolant temp. my coolant temp sensor gets to about 200. i have an aftermarket cooler, so the method mjr described wont work for me, altho i never htought of it and seems like it would work just as good.
Old May 5, 2008 | 09:31 PM
mjr46's Avatar
mjr46
^^^^^^^okaaaaay.....good enough explanation for me
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
2poor4u2
Sep 26, 2015 11:08 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
