fuel pump ?
Old May 4, 2008 | 04:44 PM
95greengt's Avatar
95greengt
Default fuel pump ?
ok im looking into gettn a new fuel pump for my 95 gt what pump should i use in the near future im gonna be doin a hci but not sure what specific components maybe a cobra intake and some gt 40 heads still not sure on what cam either i want to get a fuel pump that will be capable of running these components but still be ok with my stock setup for now any suggestions on a cam would be good as well...... any help would be greatly appreciated
thanks
Old May 4, 2008 | 04:47 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: fuel pump ?
155lph will be fine but if you have plans for a power adder in the future then go 255lph
Old May 4, 2008 | 04:50 PM
95greengt's Avatar
95greengt
if i go bigger will it still run with no problems with my engine for now
Old May 4, 2008 | 04:54 PM
NYMustang50's Avatar
NYMustang50
question mind as well throw mine in here instead of starting a new one about fuel pumps. I'm building a 347 efi for my notch what fuel pump should I use and will stock lines (I will not be using the stock fuel rail though) work for it or should I change all the lines and stuff?
Old May 4, 2008 | 05:03 PM
mjr46's Avatar
mjr46
if power output of your 347 will be under 500 then the stock lines will be adequate...and a 255 lph pump will work fine.....and it'll be fine on a stock motor because you have a return style fuel system so excess will be returned to the tank and will not cause any drivibility concerns
Old May 4, 2008 | 05:05 PM
95greengt's Avatar
95greengt
alright thanks for the info
Old May 4, 2008 | 09:59 PM
bighungrymatt's Avatar
bighungrymatt
yeah just slap a 255lph fuel pump on it and call it a day
here is a link with directions if needed
http://www.mustangcentral.net/tech/pumpinstall.html
Old May 5, 2008 | 05:54 PM
95greengt's Avatar
95greengt
yeah thats probly what im gonna do but i dont know if ill need one that big gotta give it some thought
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
Sixx
Oct 5, 2015 07:36 PM
mrappe
Sep 26, 2015 10:16 AM
