What is a good 302 setup?
Old May 14, 2008 | 01:27 PM
LyleStyle's Avatar
LyleStyle
Default What is a good 302 setup?
I have a 302 with GT40 heads and I was wondering what a good cam, intake and carb combo would be? I will be using it as a daily driverbut want as much power I can for these heads.
Old May 14, 2008 | 01:35 PM
67mustang302's Avatar
67mustang302
Default RE: What is a good 302 setup?
A decent hydraulic roller grind, simple OTS from Crane or Comp is fine in the 2,000-5,500rpm range or for a bit more power if mileage isn't a concern a 2,500-6,000rpm range cam, RPM Air Gap or for mileage Weiand 8124 and a decent little 600cfm carb. That'd be a cost effective route. You could also get a custom cam ground. It depends on what you want out of it and how much you have to spend.
Old May 14, 2008 | 02:09 PM
LyleStyle's Avatar
LyleStyle
What if I could get my hands on an E303 cam. What kind of intake and carb for that and could I expect lots of power?
Old May 14, 2008 | 03:30 PM
jtmustang's Avatar
jtmustang
do not expect lots of power from the gt40 heads and e cam
i would get a little port work done to them esp. on the exhaust side and in the bowls, but what are u doing with the car daliy driver or street/track car
Galactic
Apr 29, 2019 02:56 PM
PullTab
Oct 30, 2015 08:46 AM
mungodrums
Oct 7, 2015 04:01 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
