sits higher drag spring PIC!!!
Old May 22, 2008 | 05:43 PM
TTGreenSN95's Avatar
TTGreenSN95
Default sits higher drag spring PIC!!!
I put the drag springs on sits alot higher but it was sitting on the ground!!!! I went to ebiach drag springs in the front and put the stock springs back in the rear with the granatelli adjustable lower bar in the back so I can go up or down..
sitting just a little to high Id like to take another 1/2 to an inch lower in the front then lower the back down to match it..
I did cut a quarter of one of the coils off so it would have been even higher if I had'nt done that.
I rented a coil spring compresser from autozone the first spring took me about 3 hours to put on...I had to modify the tool to get it out of the spring after I put it in then the other spring took like 20 minutes! I dont think im going to take the tool back its hard to find one that will work for these mustang springs now this one works like a charm!!!
Old May 22, 2008 | 05:53 PM
jtmustang's Avatar
jtmustang
Default RE: sits higher drag spring PIC!!!
cool i would take a little more out of the front coils even though its a pain in the *** it will bug u if u dont i know[8D]
Old May 22, 2008 | 05:56 PM
TTGreenSN95
true dat!! im going to race it like this tommorow then cut another coil or half a coil out!I need about a 1/4 of an inch how many coils is that?
Old May 22, 2008 | 05:59 PM
jtmustang's Avatar
jtmustang
1/4 of an inch well i dont know but its probably not more than a half a coil.
Old May 23, 2008 | 02:42 AM
w8less's Avatar
w8less
about half a coil
Old May 23, 2008 | 04:59 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
What is the point of drag springs if you are gonna cut them?
Old May 23, 2008 | 08:21 AM
FivePointOhh's Avatar
FivePointOhh
in limbo
ORIGINAL: PRO50SC
+10000000000000000000000
the purpose of the drag spring being taller is to store energy and when you launch it releases the energy with a ton of force to transfer the weight......
cutting the spring you are just taking away from the performance of the part.
the other part i dont understand is i just installed mine too and it lowered it approx 3/4 of an inch from where i was stock, but my stock spring were broken in half....i dont get it.
Old May 23, 2008 | 05:46 PM
jtmustang's Avatar
jtmustang
and if u have moroso trick springs u will know as it says right in their directions that u can cut up to 1 coil off without sacrifing the integrity of the spring ,which means it will not have any effect
know on the eibach i dont know if u are allowed to do this but it says right on the directions for my moroso's
Oct 26, 2015 05:01 PM
Sep 15, 2015 07:34 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
vintageaion
Sep 8, 2015 10:45 AM
