headlight switch ?
Old May 23, 2008 | 09:32 AM
1993 5.0's Avatar
1993 5.0
Default headlight switch ?
Anyone know of a cheap replacement headlight switch (besides junkyards) I called Advance Auto and they are $48. Thanks
Old May 23, 2008 | 10:52 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: headlight switch ?
choices are limited to such but try 50resto.com
Old May 23, 2008 | 11:04 AM
1993 5.0's Avatar
1993 5.0
thank you, I will give it a shot, my truck and my mustang headlight switches both went out within 2 weeks of each other. What are the odds of that.
Old May 23, 2008 | 11:08 PM
robs87fox's Avatar
robs87fox
ORIGINAL: 1993 5.0
I've got one I'll sell you for 20 bucks plus shipping.It works fine, i bought one from 50resto when I thought mine was bad. But it was my Multifuntion switch, not headlight switch. So the switch is still good.
Pm me if you want it..
ps
are you sure its the switch, thats what i thought but I was wrong.
Old May 24, 2008 | 04:39 AM
Scout2232's Avatar
Scout2232
If your headlight switch is fried most likely you haven't done this wiring modification. I really suggest doing this at the same time you swap your switch, it literally takes like 30 mins to do and you won't have to worry about frying headlight or multifunction switches. I replaced my headlight switch twice, I wish I had done the wiring modification the first time and saved myselfsome trouble.
http://www.corral.net/tech/maintenance/foglights.html
I bought my switch from 50resto for like 30 bucks. If you switch is fried by heating up from using the fog lights I would suggest also buying the headlight switch connector also, which is something like 7 bucks. Shipping is a flat 15 bucks from them, so if you can think of anything else you want to buy from them you should get it right then.
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
StalkerGT
Nov 28, 2015 03:09 PM
guitarman376
Sep 30, 2015 05:54 PM
Drastang
Sep 29, 2015 03:31 PM
