Best Parts for Built 5.0
RE: Best Parts for Built 5.0
im in college to, and am trying to put my mustang together.......... sorry to break it to ya, but unless your parents help you, you aint going to fast to quickly
ive been working on my mustang for 4 years, and its still slow! haha but keep long term plans in mind when buuying parts other wise you will buy hting more then once and waste the very rare dollar
No, a stroker kit does not have to be over bored. 331's and 347's are typicaly 4.030", but you you can order the kit/short block for the standard bore of 4.00" which would make a 327 or 342. But in most cases the by the time the blocks are stroked there are many miles on them and they need to be bored.And there is no reason to go with a 331 and not a 347.
ORIGINAL: jtmustang
a stock 5.0 is at right about9.0 to 1
yes a 331 is a stroked crank
stock is 3.00 stroke
a 331 is a 3.250 stroke
a 347 is a 3.400 stroke
and also what is a good compression ratio to run with about an 18 psi kenne bell?>
ORIGINAL: kweb288
ORIGINAL: PJC Racing
in terms of a 331 vs a 347 i have just heard too many horror stories about 347's cracking and splitting under boost, and i just dont want that to happen to me.
ummm...dude 18psi from a kb that is not gonna last at all with the stock block.if u are seroiusly thinking about running that much boost with a built motor u need to be buying a dart,man o war,boss,r block or something stock wimpy 302 2 bolt mains are not gonna last at all
i think u need to rethink what u are doing and how much hp cause just a good block with the needed machining is gonna be another 1500-2500 bucks and then no turning back and for that much boost def. want to throw in a stout forged bottom end dude or[sm=bangbang.gif]..................................or youll be kickin yourself in the *** and pickin up pieces of your motor off the ground.
