rear end
ive noticed a humming sound comming from my rear end when im on the gas around 30+ mph its getting under my skin. with all the heat ive been to lazy to get under my car and check it out wondering if anyone has had this issue or thinks they know what is causing this?thanks
has it had gears installed before??? if so improper pinion depth setting and or backlash can cause such..also a bad bearing could cause noise but it would be noisey all the time and get louder as speed increases..if it comes and goes at certain speeds , could be an install issue
fastbackford351
Sep 12, 2015 09:42 AM
Dragonus18
Sep 9, 2015 01:21 AM
