replacing bypass hose
Old Jun 13, 2008 | 07:36 PM
5.0muscle's Avatar
5.0muscle
Default replacing bypass hose
ok ive another one for you guys that have been there and know all the tricks. im attempting to replace the short L-shaped bypass hose that goes from the thermostat housing down to the water pump. the other longer hose isnt a problem. can this be done without taking anything else off or am i kidding myself. if theres a trick to it, let me in on it. ive run out of ideas[:@]. thanks.
Old Jun 13, 2008 | 08:55 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: replacing bypass hose
GREASE the ends and squeeze the L shapped hose ends together and let it spring into place ..I use a flat blade screwdriver to push it on being careful and usually have hose clamps on hose first
Old Jun 13, 2008 | 09:03 PM
primetime5.0's Avatar
primetime5.0
i attach the end on the water pump and connect it, then put a large screw driver between it the and the thermostat housing and pry against it.. works everytime
Old Jun 13, 2008 | 10:17 PM
Boss_Hotrod's Avatar
Boss_Hotrod
I had to cut my old one off and I had to cut an inch off the new one. Use a small dab off soap on the t-stat housing and the waterpump. Itll make the hose slip on very easily.
Granatelli Sales
Jan 20, 2020 12:34 AM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
TimeLord101
Sep 4, 2015 09:27 AM
