Distributor ?
Old Jun 19, 2008 | 04:22 AM
Hollister Hoodlum's Avatar
Hollister Hoodlum
Default Distributor ?
Ok so i have a 1984 mustang lx, right now im in the process of rebuilding a 1988 motor from a lincoln.
I'm wanting to stay carb'd but im not sure how all of this will work.
Would the distributor from my 1984 mustang fit in the 1988? i don't think they will, but i don't know of any other way to get my harness to fit right.
Since it has different plug ins.
I don't know if this makes any sense to any of you, im sorry.... best explanation i can come up with...
ill post pics if that helps.
Old Jun 19, 2008 | 04:28 AM
Hollister Hoodlum
Default RE: Distributor ?
1984 distributor
1988 distributor
Old Jun 19, 2008 | 06:33 AM
stang8689's Avatar
stang8689
The 84 distributer should work with the 88 block
Old Jun 19, 2008 | 08:27 AM
BlessedHellride's Avatar
BlessedHellride
If you are going to run a roller cam in the 88 block, go to a local parts house or look in a salvage yard and get a dizzy for an 85 model GT. It has the Duraspark harness and has the correct gear on the dizzy for the roller camshaft. They are like $100 or less at places like Auto Zone and such. I almost went that route but ended up going with full MSD ignition.
Old Jun 19, 2008 | 11:59 AM
Hollister Hoodlum
ok, so an 85 will for sure work on this?
Old Jun 19, 2008 | 12:48 PM
BlessedHellride
If you are going to run a roller cam, then yes, an 85 model dizzy will have the correct gear to match a roller cam and it will have the duraspark wiring plug just like your 84 model picture.
Old Jun 19, 2008 | 02:45 PM
68CSTANG's Avatar
68CSTANG
That is correct. Dist for a 1985 with a steel gear.
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
StalkerGT
Sep 25, 2015 02:41 PM
dalehunter
Sep 25, 2015 10:51 AM
jaiidutch
Sep 14, 2015 10:29 AM
