burnout
Old Jun 19, 2008 | 10:53 PM
mattwright101's Avatar
mattwright101
Default burnout
should i be able to do a burnout in 2nd gear?
ive got stock heads and intake
f cam
flat top pistons
i think i should have enough power to do it but i just cant get em to break loose
Old Jun 19, 2008 | 10:56 PM
Baddog's Avatar
Baddog
Default RE: burnout
Do you mean getting second gear rubber after lighting them in first? Or are you pinning the tach from a dead stopand dumping the clutch in second? What gears do you have? More info on exactly what you're trying to accomplish would be nice.
Old Jun 19, 2008 | 11:01 PM
mattwright101
Default RE: burnout
i mean doing a burntout in second gear
taking the rpms up and dropping the clutch
i can smoke them to kingdom come in first
but second is a diff story
3:73 gears
Old Jun 19, 2008 | 11:07 PM
Baddog's Avatar
Baddog
Default RE: burnout
Still not enough information...If I light my tires from a light (considering I'm Trying to do a burnout), I blip the throttle twice and dump from whatever RPMI decidethen feather out to just before redline run-out (hook) then throw the clutch in with a sidestep stab of throttle to keepthe revs up, then dump again with hammer down. There are two distinct sets of footprints laid down. The second set is always paler and longer. The first gear part is shorter, darker and more dramatic and sideways if I initialize it. If you are just talking about dumping the clutch in second to do a burnout, I don't know. Sorry...
Old Jun 19, 2008 | 11:54 PM
93 LX FiveO's Avatar
93 LX FiveO
Default RE: burnout
so ur car wont spin if u dump it in 2nd?
Old Jun 20, 2008 | 12:06 AM
Baddog's Avatar
Baddog
Default RE: burnout
Me??? Dunno, never tried. Can't speak for the OP though. I've had my car for 10 months and done 1 burnout. I ****kicked my other stangs and got them (burnouts)out of my system. This one is too nice, I'd rather it hook...if you were referring to him, disregard this...
Old Jun 20, 2008 | 12:24 AM
1988GTstang's Avatar
1988GTstang
Default RE: burnout
be glad u can burnout in first lol mine has bad wheel hop right now so no burnouts for me[X(]
Old Jun 20, 2008 | 12:31 AM
Explosive's Avatar
Explosive
Default RE: burnout
I've heard a lot about 2nd being weak in the T-5. Wouldn't dumping into 2nd not be the smartest thing if you're acutally putting out some power.............
Old Jun 20, 2008 | 12:40 AM
Baddog's Avatar
Baddog
Default RE: burnout
For my settup the T5 is just fine but I don't maim it either so ???? The OP isn't making anywhere enough power to blow a T5 unless he is hellbent on doing so...
Old Jun 20, 2008 | 01:01 AM
Explosive's Avatar
Explosive
Default RE: burnout
Exactly how much HP does it take to break one ? I'm curious as to how long ours is going to last.
