body question
Old Jun 20, 2008 | 07:38 PM
1988GTstang's Avatar
1988GTstang
Default body question
i never noticed it cuz ive never seen other peoples foxbodys but i have a small gap between my fender and doors....is this normal? and how do i fix it?
http://i276.photobucket.com/albums/k...Picture035.jpg
http://i276.photobucket.com/albums/k...Picture036.jpg
http://i276.photobucket.com/albums/k...Picture037.jpg
http://i276.photobucket.com/albums/k...Picture038.jpg
http://i276.photobucket.com/albums/k...Picture039.jpg
sorry couldnt get a great pic
Old Jun 20, 2008 | 07:46 PM
AdderMk2's Avatar
AdderMk2
Banned
Default RE: body question
no, your fenders arent aligned right. someone probably pulled them out further to avoid a binding issue with the leading edge of the door
its a common problem though
Old Jun 20, 2008 | 07:47 PM
1988GTstang
so can i adjust them right or do i justleave um be?
Old Jun 20, 2008 | 07:51 PM
5.0stanger's Avatar
5.0stanger
Is there a gap on top of the fender where it meets the cowl? That isn't right and should be able to be aligned.
Old Jun 20, 2008 | 08:00 PM
1988GTstang
yea a small one
Old Jun 20, 2008 | 08:06 PM
Boss_Hotrod's Avatar
Boss_Hotrod
There should be abotu a quarter inch gap between the door and the fender as well as the fender to the cowl. If the gaps look okay the way to fix it is to losent he bottom bolt and pull the fender downward. This will "stretch" the fender so it fits the contour of the body. If you do this and there is not a 1/4" gap between the door and the fender either the door or the fender needs to be slid backward or forward depending on which is incorrect. door to quarter gap should be about a 1/4" also.
I just went and looked at my car and the gap from the fender to the cowl is closer to an 1/8" inch more than likely 3/16". Id try the bottom bolt first. Just make sure the top of the fender is in line witht the door skin and go from there.
Old Jun 20, 2008 | 08:12 PM
1988GTstang
so its just adjustments? its not like i need to replace them or anything right?
Old Jun 20, 2008 | 09:03 PM
Boss_Hotrod
Probably not. if nothing looks bent or creased it just adjustment.
Old Jun 22, 2008 | 02:35 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
the problem is from jacking up the car wrong and bent the fender, by putting the jack in the wrong place
Old Jun 22, 2008 | 02:47 PM
1988GTstang
so replace the fenders?
