body question
Old Jun 22, 2008 | 02:48 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: body question
no you can loosen them up and flex them and add shime etcs
Old Jun 22, 2008 | 03:23 PM
1988GTstang's Avatar
1988GTstang
iight..
i also have a few rust spots...the quarters im not worried about because im replacing both...the doors have a few surface rust spots that im going to sand down but the spot that bothers me is on the passenger side door jam area...its a very small spot...can i just cut out a piece of sheet metal and weld it over ?
Old Jun 22, 2008 | 03:35 PM
Boss_Hotrod's Avatar
Boss_Hotrod
No. You never want to weld over rust. Cut out the rust and make a patch panel to go in the hole. Then butt weld it into place and do some filler work.
Old Jun 22, 2008 | 03:37 PM
1988GTstang
oh my bad thats wut i meant bro...cut that rusted spot out and then weld a new piece in
Old Jun 22, 2008 | 03:38 PM
Explosive's Avatar
Explosive
What is with the guy and the faces ?
Old Jun 22, 2008 | 03:43 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
idk a noob i guess? i thought that smilies without text wouldnt show, i know it has before when i did it in off topic.
Old Jun 22, 2008 | 06:29 PM
1988GTstang
i took a few pics of the rust spot i was talking about so u guys can tell me how bad it is and if anybody has an idea of how much it would cost me to get it fixed
http://i276.photobucket.com/albums/k...Picture040.jpg
http://i276.photobucket.com/albums/k...Picture041.jpg
http://i276.photobucket.com/albums/k...Picture042.jpg
Old Jun 22, 2008 | 06:59 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Anyway about the adjustments. There is a bolt on the bottom of the fender by the door(shuold be covered by the splash sheild of the fender) and on the inside of the door jam when you open the door. Loosen those and try to get it aligned right. You may have to loosen the back one under the hood also.
Luke9222
Oct 22, 2015 11:55 PM
copestang
Oct 11, 2015 07:17 AM
GimpyHSHS
Sep 18, 2015 12:27 PM
Mustangmalo
Sep 6, 2015 05:22 PM
