If you get the patch piece yourself and do the prep work.. It should not cost much at all to have someone weld it in. Its better to fix this sooner than later... Right now it doesnt look that bad.
It will proably cost $20 to ship it....$10 is a good deal. It is the bottom rear corner of the door frame, cut out of the car from below the striker to about 6" into the jamb all the way back to the wheel(I used the out side area to patch my car). I guess I can cut it up a little so it isn't as big so it will cost less to ship.
