sensor location/replacement
Old Jun 23, 2008 | 04:11 PM
1988GTstang's Avatar
1988GTstang
Default sensor location/replacement
on a 88 where is the coolant temperature sensor and how quick is it to replace it?
Old Jun 23, 2008 | 05:39 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: sensor location/replacement
It's the sensor in the middle of the picture and it's very easy to replace.
Old Jun 23, 2008 | 06:55 PM
ryan_89_mustang's Avatar
ryan_89_mustang
I replaced mine a couple weeks ago its not too bad, you might want to put a sheet of cardboard under your engine or some newspaper because some coolant will come out of the hole. Just get the new one in the hole quick and your set. If you have the stock gauges make sure you get the sensor with the green insulator (I made the mistake of getting the black one)
Old Jun 24, 2008 | 08:03 PM
Boss_Hotrod's Avatar
Boss_Hotrod
The picture is the temperture sender. The sensor is on the other side of the intake on the heater rail. Its on the front of the rail near the thermostat housing.
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
TfcCDR
Sep 14, 2015 12:08 PM
