cam advice
Old Jun 27, 2008 | 07:38 AM
wiljersey's Avatar
wiljersey
Default cam advice
is this a good choice. i have upper and lower gt40 intakes. i have gt40p heads but want to change the cam when i do the heads. willl this make good power, if not what will i have heard to stay away from the letter cams. im new to this so please help me out.[/align][/align][/align][/align][/align][/align]
Mustang Roller Camshaft, Track Heat - 5.0L/5.8L Stage 2 [# TFS-51402001 ] Fair idle, good midrange power. 2,500 to 3,000 rpm stall converter or five-speed recommended. Compression ratio: 9.5:1 to 11.0:1. Duration @ 050" (degrees) - 224 intake/232 exhaust Cam Lift (intake/exhaust) - .339"/.352" Lift w/ 1.6 rocker (intake/exhaust) - .542"/.563" Lobe seperation (degrees) - 112 [/align]
$164.95 [/align] [/align][/align]
Old Jun 27, 2008 | 02:10 PM
sn95_331_GT_ yellow's Avatar
sn95_331_GT_ yellow
Default RE: cam advice
absolutely not.
first of all, you havent given enough information, but i assume your wroking off of the stock pistons.
therefore, that cam will in no way clear the pistons. anything over .512' needs to be notched. see the problem.
we are supposed to have 9:1 compression, but its never over 8.9:1. that cam needs 9.5+...
that cam is also too much lift for those heads.
the alphabet cams are great i dont know what youve heard, and you really cant beat their prices either.
e303 is a good all around cam, b303 will give you better top end a choppier idle.
TF stg 1 is another option.
depending on what year your car is Steeda #18 or #19 cam will work as well.
Old Jun 27, 2008 | 02:19 PM
Dazzalad's Avatar
Dazzalad
My top 2 suggestions would be:
TFS Stage 1
Ford B303
Old Jun 27, 2008 | 03:51 PM
NoGo95GT's Avatar
NoGo95GT
Get the TrickFlow Stage 1 cam, it's even cheaper than the stage 2. The Alphabet cams are outdated. They are a single pattern cam. I believe. The TrickFlow is a dual pattern cam. The E-cam does sound good, but so does the TrickFlow stage 1 and it makes good power to 6,000rpm, plus the TrickFlow cams are cheaper than the letter cams. Since you have a mild head and intake system, there is no need to get a custom cam, unless you add a poweradder in the future
Old Jun 27, 2008 | 04:06 PM
joeymustang's Avatar
joeymustang
With what you got...go with a B-303 and some 1.7 FRPP roller rockers...
Old Jun 27, 2008 | 04:28 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
ORIGINAL: sn95_331_GT_ yellow
absolutely not.
lift has nothing to do with PTV!!!AND ALPHABET CAMS ARE OUT DATED..much better choices out there......what we need to know is the entire build you have or intend to evaluate your choices
Old Jun 27, 2008 | 06:28 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
The duration is what determines the PTV clearance. With those heads the stage 1 would be better though. Whatever you go with be sure to get springs that can deal with the cam.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Luke9222
Oct 22, 2015 11:55 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
