Which is faster?
Old Jul 11, 2008 | 01:21 PM
bigpapi48's Avatar
bigpapi48
Default Which is faster?
Which is faster a manual or atomatic with a shift kit?
Old Jul 11, 2008 | 01:29 PM
OneFastEclipse's Avatar
OneFastEclipse
Default RE: Which is faster?
stock for stock, the manual.
Old Jul 11, 2008 | 01:31 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
It will also depend on the driver
Old Jul 11, 2008 | 02:11 PM
ckyguy68's Avatar
ckyguy68
These cars have similar mods aod vs 5speed
http://videos.streetfire.net/video/T...-in_160204.htm
Old Jul 11, 2008 | 05:17 PM
Milton's Avatar
Milton
the 5speed has advantage due to the tall first gear 3.25?(if i remember correctly) and aod has a 2.40. but if the 5speeddriver cant drive...
Old Jul 11, 2008 | 05:21 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Stock for stock the 5 speed, but add the right torque converter to the mix and the auto will usually clean the 5 speeds clock.
Old Jul 11, 2008 | 07:35 PM
94StinkinLincoln's Avatar
94StinkinLincoln
it depends...
same rwhp, it might be real close
for instance the tko600 has a great 1st gear for modified cars, 2.8x 1st
the aode has a 2.4 1st and the 4r70w has a 2.8x 1st.
a stock converter or low stall kills the off the line performance.
if you got a modified valve body/ shift kit and the CORRECT converter, with close to the same gearing and same rwhp and power curves and same rear end gears, same car weight,then the auto has the upper hand.
in most apps, a 11 sec car or slower, will be faster with a 5 speed.
Old Jul 11, 2008 | 08:51 PM
ZachW04Stang's Avatar
ZachW04Stang
It depends how fast you can shift. Some people can run the same motor faster with an auto, some a stick.
Old Jul 11, 2008 | 09:18 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
you'll need more than a torque convertor to make the auto win...the aod's gearing has a lot to do with it plus the slippage and loss of hp through the auto the aod has a 2.40 first gear vs 3.35 of a t-5
Old Jul 11, 2008 | 09:33 PM
ZachW04Stang
Plus an aod weighs a hell of a lot more then a t5.
