suspension install
Old Jul 12, 2008 | 08:39 PM
1988GTstang's Avatar
1988GTstang
Default suspension install
how hard is it to replace front struts...quad shocks....rear shocks and rear control arms? any special tools needed?
Old Jul 12, 2008 | 09:10 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: suspension install
impact tools make it a little easier and quicker
Old Jul 12, 2008 | 09:12 PM
my little red 90's Avatar
my little red 90
no and no.
most good equipment come with good directions.
i use maximum motor sports peices. they are high quality, you can get good tech help and the directions are great. complete with photos of what is supposed to be happening.
if you mess with the springs, you can rent spring compressors from some parts houses. pay attention when changing springs as they have energy stored when the springs are compressed and can be hurtful to the human body. not really much risk if you study up a little.
Old Jul 12, 2008 | 09:21 PM
93 LX FiveO's Avatar
93 LX FiveO
ugh... i find all of the above easy to install.
i installed my rear springs, shocks, and removed quad shocks without a hassle.
biggest PITA was installing the shocks without the shaft spinning as you turned it. i had a friend hold it while i torqued the bolts down.
the springs are a little tricky. i was able to use one of the 2 post lifts at work so i had my friend hang onto the rearend as i put the springs into place. while he was still hanging on the rearend i had to "tap" the springs in the cups.
i was installing lowering springs so no compressor was necessary.
front is a bit more tricky but if you're replacing control arms a floor jack should be all thats necessary.
if you need help, let me know
Old Jul 12, 2008 | 10:30 PM
bighungrymatt's Avatar
bighungrymatt
its not bad at all, get a buddy to help and you can knock it out in no time
Old Jul 12, 2008 | 10:46 PM
1988GTstang
well yea i got two friends helping me i dont think ill have a hard time wit the rear it seems pretty simple...im worried more bout the front struts....i think ima have a hard time wit it
mtgldr
Feb 3, 2024 09:00 PM
GimpyHSHS
Sep 18, 2015 12:27 PM
RWHEELS
Sep 5, 2015 03:42 PM
