is there anything special involved with this setup?
to install it in a fox you'd need to swap timing covers and use the long block ......but motors are the same except when you go back to 92 and below to 85 where pistons were forged
Well, the timing cover needs to be changed because of the difference in the accessories and the intake for the 94/95 has an elbow in it that the 93 and earlier engines didn't due to differences in the engine bay.
Hmmm...Come to think of it, the 2 SN95's that I've worked on, had Cobra intakes. Those elbows are bolted on. I hadn't actually considered that the stocker was one piece.
