IAC
Old Jul 17, 2008 | 05:43 PM
1988GTstang's Avatar
1988GTstang
Default IAC
is there any way to test the IAC? my car surges and i have a feeling its the IAC but i dont want to buy one if its not the problem...the throttle is clean and a has a new TPS so i know thats not the cause
Old Jul 17, 2008 | 05:55 PM
ewgoetz's Avatar
ewgoetz
Default RE: IAC
try disconnecting it. If the surging stops it should be it.
Old Jul 17, 2008 | 06:00 PM
Hung Like a Stang's Avatar
Hung Like a Stang
Default RE: IAC
there should be an ohm spec on it. However I don't know what it is. but ewgoetz's method should work.
Old Jul 17, 2008 | 06:20 PM
1988GTstang
Default RE: IAC
i tried that method....if i unplug it the car dies out
Old Jul 17, 2008 | 06:28 PM
Hung Like a Stang
Default RE: IAC
found the spec. 7-13 ohms.
Old Jul 17, 2008 | 06:35 PM
1988GTstang
Default RE: IAC
iight now where i check it?
Old Jul 17, 2008 | 07:51 PM
93 LX FiveO's Avatar
93 LX FiveO
Default RE: IAC
when u first start it what does it do?
Old Jul 17, 2008 | 07:54 PM
1988GTstang
Default RE: IAC
there are two things it does...sometimes ill start it and it will surge about 500 rpms for a while and then settle down and idle fine...other times ill start it and it will idle fine and then oncei start drivin it will start surging once im at idle
ShaneB26154
35
Mar 4, 2021 04:05 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
lmurf60
Sep 24, 2015 10:07 PM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
fdnyems19
Aug 13, 2015 09:36 AM
